Mirror Mounting on Plasterboard
MattJ0000
Hi, I am looking to fix a 5.5kg mirror on a plasterboard wall. Can someone please recommend the best type of anchor or a better method of hanging? I've attached a photo of the mirror and the holes on the back of the mirror that can be used for mounting. Thanks!
Re: Mirror Mounting on Plasterboard
Hi @MattJ0000,
Provided there is more than one fixing point, you can use these  Zenith 10kg Zinc Plated SureHook Plasterboard Picture Hangers. You'll need to take some fairly precise measurements and transfer them to the wall to position the mounts.
Once the mounts are installed on the wall, insert the screws and leave their heads about 5mm out from the wall. You'll then be able to hook your mirror onto them.
