Insulation of Aluminium front door to reduce noise
Wookie45nz
16249580478182857241499875720044.jpegWe have  Strata aluminum front door but as it is not insulated it allows a lot of traffic noise through.
Can this be easily insulated?  Thanks..
redracer01
Re: Insulation of Aluminum front door
Hello @Wookie45nz
Welcome to Bunnings Workshop and thank you for sharing your question with the community. I would like to say that it should be easy to insulate the aluminum door, but to be safe and thorough can you please post a picture of the actual door that we need to insulate. This will greatly assist us and allow our members to determine what kind of insulation we can recommend.
Red
Welcome to the Bunnings Workshop community @Wookie45nz. It's fantastic that you've joined us, and many thanks for your question about sound insulation for a front door.
Was your door something similar to the Strata 2040 x 820 x 41mm Parkwood Aluminium Entrance Door
Some things you could try would be installing heavy woollen curtains or acoustic drapes across the door, adding Raven door seals to seal all gaps and attaching foam tiles to the back of the door. If you have solid floors, placing a rug down behind the door can inhibit the sound waves bouncing around and penetrating further into your home.
I look forward to following along with your project and providing further assistance.
Image..I hope.
Hello @wookienz,
Are you trying to attach a picture to your post? Just a reminder that the picture has to be either a .jpg or .png format. Please remember to use the "Upload Images" button at the bottom of the response screen and then choose your photo and press "Done" to apply the changes.
If the picture does not show up on your post please let me know.
StevieB
Retired Team Member
Retired Team Member
Great to see that you were able to share that photo with us @wookienz and please let us know if you ever need help navigating the site. We're here to help.
I see that you've already received a few suggestions from @MitchellMc. @EricL will be happy to help further when he's back on the site on Friday. Thanks for your patience in the meantime.
Stevie
See pic below in other post..
Hello @wookienz
Thank you for posting the picture of your door. To stop draught from entering the gaps between the door frame and the door, I suggest using the Raven 5m Door And Window Seal - RP14 White. You can also use the Sperling 78cm Double Sided Draught Stopper to stop the wind from entering through the bottom of your door.
Here is a handy guide to give you more ideas:  How to winter-proof your home
If you need more information please let us know.
wookienz
How to insulate front door?
Hi. Keen to insulate this Strata front door. Easy to do?
