Insatlling lining boards with invisible brackets
belhamel
Hi, I'm currently building a sauna and I'm about to install the interior boards. I'm going to use Thermory boards. I'd like to use hidden brackets to install them, but can't find any. Any recommendations? I've tried nails, but the profile makes it tricky. I've found these, but they are only in the UK.Thermory_Sauna_wall_STP_15x90_alder_1920_2.jpgfixings.jpeg.
Re: Insatlling lining boards with invisible brackets
Hello @belhamel
Welcome to the Bunnings workshop community. It's sensational to have you join us, and thanks for sharing your question about installing your lining boards with hidden brackets.
I've had a thorough search, I'm sorry but there are currently no compatible hidden fixings available for your Thermory boards. For traditional fixings, I propose having a look at the Bremick Ultrafast 10g x 50mm Stainless Steel 316 T20 Trim Head. Its trim head provides a small and discreet finish, plus its precision T20 drive resists cam out.
My best advice is to drill pilot holes just to make sure that none of the boards split when being fixed in place.
