How to sand back paint on trims?
amy2
Growing in Experience
Hi fellow reno's,
I am starting on a project. Sanding back flaking paint on window/wardrobe trims. These are the tools am using. Plus have electric sander to do tougher jobs.
amy2
Re: any advice on Sanding back paint on trims?
Thanks very much for the advice!
amy2
Hi Mitchell,
Still on this project.....
Can you direct me towards any tutorials on this Bunnings workshop site that could offer me advice for applying undercoat?
Thanks so much
It's great to hear from you @amy2!
You might like to read through this step-by-step guide: How to paint like a professional. It touches briefly on applying undercoats. However, applying an undercoat is much the same procedure as painting.
If you'd like to post some pictures of the surfaces you are planning on undercoating, I'd be happy to provide advice tailored to your project. The most important choice is likely what type of undercoat you'll use. Recently I've been using Dulux 1L PRECISION Maximum Strength Adhesion Primer White on any surface that has more than a low-sheen to it. Traditionally you'd need to scuff up or remove any gloss paint before undercoating. This new product will adhere to the gloss surface with only a slight sanding. For a general-purpose undercoat, I go with Dulux 1Step Prep Primer, Sealer & Undercoat.
I look forward to seeing some updated images of the project and providing further assistance.
Nanne
Building a Reputation
Hi MichellMc
Is there a power tool that can be used for sanding trims, corners, skirting boards? I have Ozito 1/2 sheet sander and Ozito detail sander. The details sander is just a little bit too big for skirting boards etc.
Hi @Nanne,
A Multi Function tool with a sanding attachment would likely be the next size down from a detail sander. The tool is longer, but the sanding pad is smaller, allowing you to get into tighter spaces. We have the Ozito 300W Multi Function Tool and Ozito PXC 18V Multi Function Tool if you want to stay within the Ozito range.
amy2
This is the finished product of my painting project. Photos are way over due to be shown. I finished the house painting last year. StaircaseStaircase
Hello @amy2
Thank you so much for the painting update. Your painting project looks fantastic! All that sanding and preparation has paid off as your banister and handrails look amazing.
Again, thank you for sharing the results of your painting project.
