Honest52
Building a Reputation
How to replace garage gutters?
How to replace old gutter for garage?
Our old garage gutter is metal , and rusty, with broken down pipe. It's about 10m long.
I plan to take it down and install new metal gutters and pvc down pipe.
To prepare materials: colour bond 115mm x3m gutter x 4 nos
Colour bond external brackets x5 nos
Colour bond lh stop end and rh stop end
H
Abey 80mm round downpipe pops
Icon 80x3m round down pipe
Icon 80 95dg socket bend downpipe  x2no
Icon 80mm round downpipe clip x2
Could you please check and advise anything missing or tips?
Re: repair garage old gutters
Hi @Honest52,
Your material list looks quite comprehensive, but there are a few additional items you may need. Masonry fixings will be required to secure the downpipe brackets, and pop rivets and gutter silicone sealant will help ensure a watertight join of the pop outlet. Additionally, you might want to check if you have enough brackets, as spacing them every 900mm to 1200mm is generally recommended to provide adequate support.
When installing the new gutter, make sure it has a slight fall towards the downpipe to allow proper drainage. It’s also important to check that the fascia is in good condition before attaching the new gutter. If the old one was rusted, moisture damage to the fascia could be a concern.
Keep in mind that in many areas, installing guttering and especially connecting a new downpipe to the stormwater system is considered plumbing work that requires a licensed plumber. It’s best to check the regulations in your area before proceeding to ensure compliance.
Honest52
Thanks Michell!
The aluminum drainage pipe is not easy to install for the connection joints and fittings.
Is it better to use PVC drainage pipe and fittings for this old house? Cutting PVC pipe seems faster than aluminum drainage pipe?
Hi @Honest52,
Yes, PVC downpipe would typically be easier to cut and install than steel downpipe.
