Hey Guys
I am removing old wooden door jambs and re-sanding my floorboards - However, as you can see, where I have removed the door frame, I am left with a hole in my floorboards each side. In the hole there is some concrete which i assume are foundations. When i replace the skirting i think about half of these holes will still be showing. What would you suggest i can do to fill the holes? any suggestions are very much appreciated -
Hi @elbow,
Thank you for your question about filling some gaps in your floorboards where a door jamb was removed.
The only solution I see is to remove the cracked mortar/concrete, slip a piece of timber underneath the existing floorboards to bridge the gap, screw through the existing floorboards into that piece of timber to lock it in place and then put a piece of timber into the gap that is the same thickness as the floorboards. This will finish the flooring at the same height as the existing stuff, which we can then stain and varnish as closely as possible to its surrounds.
If you had a spare floorboard anywhere, this would be ideal, but if you don't, can you advise how thick the floorboards are so I can recommend a suitable timber for this?
Can you also let me know how much of a gap there is underneath the floorboards once the cracked concrete/mortar has been removed so I can recommend a timber to act as a back block?
Let me know what you think.
Hey Jacob, thanks for coming back,
Seems like a reasonable suggestion. I've added another pic for clarity and better angle. No spares anywhere unfortunately. The board thickness is 22mm and the gap underneath the board to the concrete is 25mm
Hi @elbow,
With those gaps, it makes sense to use the same material both as the blocking beneath and as the actual filler piece.
I've found the following options which are 22mm thick.
There is 90 x 22mm Decking H3 Treated Pine. It is the most cost-effective material I could find, but it would be lighter than the surrounding timber and would need to be stained.
There's also the 100 x 22mm Western Red Cedar and 150 x 22mm Western Red Cedar which will match the thickness well, and are a darker timber than the pine, but they are rough sawn and would need to be sanded to act as flooring. These profiles will need to be special ordered if you'd like to use them.
The other alternative, which I think will look the nicest, is to use 110 x 19mm Tasmanian Oak with 3mm of packing material to raise it up so it is flush with the surrounding floorboards. You can use a piece of 3.2mm Masonite and sand off 0.2mm from the Tasmanian Oak so everything sits flush.
Hey Jacob, i like the last option, ill be popping into my local bunnings to pick up the materials, thanks so much for your help, much appreciated.
It'd be great to see some photos once it's done. I'm sure it will look excellent.
Let us know how you go @elbow.
only prob is i cant get any masonite at katoomba where i live (2780) - any alternatives??
Hi @elbow,
You can just use Window Packers. You'll want to pack out both sides of the Tas Oak with either 2 x 1.5mm packers stacked on top of each other or a 3.2mm packer.
ha i did wonder - ok cool ill go with those - Big thanks Jacob!!!
