How to repair a Trimdek and Colorbond roof?
JustinMcAbbe
Building a Reputation
Hello
I am trying to self repair our roof as we can't find any one atm. This roof is
Trimdek and Colorbond, Please can you advise what is the best way to fix the following two problems;
1) Hole in Trimdeck
2) Missing Flashing
Re: How to repair a Trimdek and Colorbond roof?
It sounds like you're after roofing screws @JustinMcAbbe. You have the longer Buildex 12-14 x 50mm Climaseal Hex Head Hi-Grip With Seal Roofing Tek Screws, and the shorter colour-coded Roof Zip Head Head screws.
Your list appears to be fairly comprehensive, and you should have everything you need.
Dulux Acratex is certainly a premium option that you can use on your roof, and it's typically considered the trade and more robust alternative to the Weathershield range.
