How to remove the protective film on Gorilla tape?
Ronb1949
Does anybody know how to easily remove the protective film on Gorilla tape? I've tried using a sharp knife to separate the layers, but I still end up with a crumpled corner!
Re: How to remove the protective film on Gorilla tape?
Hi @Ronb1949,
Gorilla mounting tape is particularly sticking; that's why it works so well. I find it best to cut the length I need and then adhere it to one of the surfaces, pushing it firmly in place, especially the corner I'll be removing the film. I then take a knife and pry up the corner of the backing film. If I cannot adhere the strip first, I pinch the mounting tape on the back corner with my fingernails and then, whilst pulling it away and pick the corner of the film up with a knife.
Typically, I end up with a somewhat distorted corner, but generally, that doesn't affect the use of the mounting strip. How badly are your corners crumpling? Perhaps you could share an image with us.
