Earlier posts say drill out pot rivets securing bottom latches of vertical flyscreens to allow inserting new mesh and spline but doesn't explain steps to reattach pot rivets to latches. HELP pLease would be much appreciated.
NOla Davies
Welcome to the Bunnings Workshop community @nolabearbear. It's wonderful to have you join us, and many thanks for your question about re-attaching latches.
Was there a particular discussion you were referencing? If you could provide a link, that would assist in giving accurate advice. However, if you've drilled out a pop-rivet to remove it, then to re-attach the latches, it sounds like you'd need to pop-rivet it with a rivet gun.
The new rivet is installed in the gun and placed through the latch into the hole. The gun is then action to crimp the rivet and fix it and your latch in place.
Here's the link to the discussion. Thank you, I think you have answered by saying use a pop rivet gun. For some reason, I thought it might be possible to hammer them in. CHEERS
