How to patch internal wall render?
Hello
I had a new kitchen installed and during demo some of the render was damaged. How can I repair this?
Re: Redner wall patch
Welcome to the Bunnings Workshop community @ceilingfan. It's sensational to have you join us, and many thanks for your question about repairing render.
As your render does not have a gritty texture, I'd recommend using Dunlop 5kg Ardit Rapidset Repair Mortar. Use a trowel to apply the product to the surface and immediately smooth off. After approximately 15 minutes, finish off with a wet trowel and use a sponge to eliminate trowel marks and obtain a smoother surface. Here's the application guide.
You'll want to apply painter's tape to the cabinetry to prevent the cement product from getting on it.
Once the patched area is dry, you can undercoat and then once it's dry paint.
Thanks Mitchell, that’s great. I will try this now.
