Hi Bunnings Community,
I'm planning a renovation project to transform our rumpus room on the back of our garage into a combined study and laundry room, and I could use some advice. Here's an overview of what I'm aiming to do:
Room Size: 5m x 4.6m
Flooring: The existing concrete floor is uneven (higher in the center). I plan to level it - I a considering a self-leveling compound and cover it with water-resistant hybrid flooring panels. Any product recommendations for these materials?
Room Division: I want to divide the space into a study and a laundry area using a permanent wall. What type of materials and insulation would you suggest for this purpose, especially to keep noise from the laundry down?
Ceiling: Planning to install a drywall ceiling that can be easily attached to the existing garage cross beams. There is some insulation already in the ceiling that was done for the rumpus and plaster covering between the beams.
Wall Covering: I’m considering using VJ paneling for the walls. Could you recommend paneling? does anything need to go between the paneling and bricks? (the existing walls are brick)
Lighting: I plan to install recessed lighting in the ceiling with the help of an electrician. There is wiring already there to utilise.
Please see rough plans in the images
Thanks in advance for your help! I appreciate any advice or recommendations you can offer
Hi @mgs788,
Thank you for your question and welcome to the Bunnings Workshop community, it's brilliant to have you with us at the planning stage of such an exciting project.
There are many members, such as @Nailbag @Dave-1 and @Jewelleryrescue who are experienced renovators and I'm sure they'll be happy to join in on the discussion and offer their advice and experiences.
One of the best things you can do is upload a few photos so our members can run an eye over things and maybe point out anything you may have missed.
Allow me to offer some advice on each individual area.
There are a million things to consider when planning a renovation and it is very hard to think of everything. You might like to have a read of these handy articles for a bit of guidance and inspiration -
Hopefully this gives you some good information to start with and opens the conversation for us to help this project come to fruition.
Let me know if you have any further questions or would like any clarification or advice moving forward.
I'm excited to see this project come to life!
Hi @mgs788
I'm only going to comment on a few suggestions outside of the already amazing detailed ones that @JacobZ has provided.
Flooring: Before starting anything, I would get a plumber in to discuss how water and waste will need to be handled as it may require cutting channels in to the slab for access.
Room Division: In addition to the acoustic installation I would line the walls with "Superchek" or similar acoustic plasterboard.
Ceiling: Definitely go with ceiling battens as Jacob suggested, much easier to level,
Wall Covering: I Love VJ paneling but only for a feature wall not all 4 sides as personally the lines would be too much. Plus you will loose the opportunity to use Superchek. So, I would attach these sheets directly to the brick walls which is super easy.
Lighting: Definitely get the sparky in at planning stage.
Doors: You won't get a 720mm (smallest) cavity slide frame for the laundry as it needs 2040mm but allow more for packing and architraves. So unless you can move the diving wall in to the study you will have to consider normal swing doors. All others are fine with standard 820mm cavity sliders.
Nailbag.
Good Evening @mgs788
Both @JacobZ and @Nailbag have really pointed out anything I could add
Jacob and Nailbags suggestion about the cavity doors is really something I would take into account.
The ceilings joists above may look level but probarly wont be so battening it out will make that a lot easier.
There is no window in the new study? Is the door going to be glass? Looking at your drawing it could be a double glass sliding door? Some photos would help visulise things that we may be presuming
The last thing I can add is to do sketches and more sketches of the ideas and how you would impliment them. It really helped me out nutting cornice, door jambs ect out. One last suggestion before you start would be to mark out with tape on the floor all the dimensions of the rooms and doorways. Then step through and see if they feel comfortable. Lots of times I see too small an allowance for cornering and access. Make sure you are comfortable with the space. I was just looking at your 2m width for your laundry. The wall will chew up a bit as will the door widths. Check to see if whare you are placing the washing machine, dryer ect all pass that floor test.
Awesome - thanks so much @Dave-1 @Nailbag @JacobZ
Useful suggestions. I reckon we will opt for superchek just for the ease.
Glass sliding door to a little courtyard space (next project is decking over the concrete). We will also have sky lights installed for more light in the study.
With plumbing - we are planning on using a pump out system like a saniflo system as the space is lower than the sewage line. Have you guys had any experience with these systems? It still might involve cutting the slab and pumping from under the house rather than in the laundry. (sounds like a mess but I think it will work!)
We will drop the laundry door way to the right, as you guys pointed out it will be tight for space and on reflection not really required.
Attached are a few photos of the space. The red line indicates where the divide is.
The door you can see goes to the garage.
Looking from the garage door into the room
Hi @mgs788 Looks like you have some great spaces there to work with.
In dealing with the surface electrical conduit, get your sparky to relocate them down between the cavity. Since your cover the walls over and installing a lowered ceiling, there will be no issues with access. New cables can run wall to wall via the ceiling and knocking out top bricks will access the cavity. Then knocking out a brick at the new points for light switches and GPO's. See a few samples below when I had to do the same. To save labour money on the sparky, I knocked the bricks out and fed new cables or you can at least run the draw-strings.
Some years back I helped my next door neighbour with a front of house garage to master bathroom and ensuite renovation on a slab floor and a flat roof. The side of his house the ensuite backed on to had a concrete path and the sewage was along the back fence. Since we couldn't run the waste down or out the side the only direction left was up and over the roof to the back of the house with a similar system to the Saniflow. It was all automatic and worked very well. Obviously all this work was done by a licensed plumber, who we helped with what was needed along the roof to both support the pipes and conceal it from view.
Nailbag.
I
Thanks @Nailbag
useful images. I’ll do that to save on electrician costs.
Do you mind sharing what system you used for the pump out?
Sorry @mgs788 the plumber supplied the system so I don't know the brand. It was about 4yrs ago and so I'm sure there would be advancements in the tech since then.
