How to install curtains with bulky architraves?
diybeginner2
Hi all! I’m hoping to install some s-bend sheer curtains here, but am a bit puzzled on the best way to do so given the bulky ‘decorative’ corners in the ceiling.
I’ve included a picture that shows the look I’m going for. Ideally the curtain rod would cover the entire width of the blinds.
Any suggestions are greatly appreciated.
Re: How could I install curtains here
Hello @diybeginner2
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about curtain installation.
I suggest covering the indentation with timber as it will create a flush surface for securely mounting the curtain rod. To ensure stability, you might want to use a piece of timber that fits snugly within the indentation and secure it with construction adhesive, screws, or brackets, depending on the material of the existing wall. If the decorative feature is plaster or another soft material, using wall plugs or toggles may help reinforce the attachment.
Another option is to install ceiling-mounted curtain tracks, which could allow you to bypass the indentation entirely while still achieving the full-width sheer curtain look. If aesthetics are a concern, painting the timber to match the existing wall or ceiling could help it blend in seamlessly.
Re: How to install curtains with bulky architraves?
Hi @diybeginner2,
If you'd like assistance with the installation, we also offer a professional curtain and blind installation service. Our team can help with the entire process, ensuring your curtains are installed perfectly. Just see the team at your local Bunnings store's Special Order desk to organise the installation.
Please let me know if you'd like further details.
