Noticing ants getting in and out of a few gaps between the wall and the floor in my living room. I don’t have skirting boards btw. I’ve removed all food sources, cleaned floor and washed bins but it just gets worse. Ants even getting on my couches.
I bought ant-rid liquid to poison them. When they die off, should I seal the gaps between the wall and the floor? Caulking?
Hello @ejo
Thanks for sharing your question about sealing the edge of your wall. You are technically halfway there as you've already applied the ant-rid. Sealing the gap is the next step in reducing the ant's entry points in your house.
I propose using Selleys 475g No More Gaps Interior Multipurpose Gap Filler. It is an easy-to-use gap filler ideal for filling gaps and cracks around skirting boards, cornices, and inside window & door frames. The water-based formulation has been designed to cope with building movement to ensure a long lasting and crack resistant finish.
Here is a handy step-by-step guide: How To Silicone Seal A Bath (the techniques used are applicable to your project)
Please make sure to wear personal protection such as gloves and goggles when working on your project.
