How to build a raised platform?
selfwork
How can we build a raised flatform for spa pedicure area, the platform is 20cm high x 2.4m wide x 6m length
Re: how to build a raised flatform 20cmx2.4mx6m
Welcome to the Bunnings Workshop community @selfwork. It's wonderful to have you join us, and many thanks for your question about building a platform.
You can construct a sturdy raised platform using 90 x 45mm timber to build a solid frame. Space the timber joists evenly at 450mm centres to provide proper support, then clad the frame with Yellow Tongue 3600 x 600 x 19mm flooring for a durable base. Once the structure is in place, you can explore finish options such as Hybrid Vinyl Flooring to create a professional and easy-to-clean surface.
I've created a couple of renderings to assist with the assembly process.
Thank you so much for your help MitchellMc
