Hey Team
My questions are about light dimmer switches/fan controllers. They are:
1. What physical controls are available on the switch itself.
Eg: long press for dimming
Double press for full brightness
Single press for on and off(last dimmer setting)
2. How many dimmers can I gang on a face plate?
3. Same questions as 1 and 2 but for fans?
These are my expectations^ but are they reality?
Cheers
Justin
Welcome to the Bunnings Workshop community @Justin91. It's brilliant to have you join us, and many thanks for your question about Grid connect products.
The Deta White Grid Connect Smart Touch Single Dimmer only comes in a single gang. If you need additional dimmers on the same wall plate, you can use a DETA X6 White Triple Vertical Switch—3 Gang and replace the switches with Deta Grid Connect Smart Dimmer Mechanisms. The switch's operation is as follows: The first touch to turn it on, the second, third and fourth touch to set brightness from high, medium, and low, and the fifth touch to turn it off. The app can implement additional features.
The Deta Grid Connect Smart Fan Speed Controller with Touch Light Switch - Gloss White left switch turns the light on and off, the middle turns the fan on and the third cycles the speed.
Since the smart fan switch implements three switches, you could only have one fan on each wall plate.
