Hello,
I'm really struggling to find the right approach for transitioning my kitchen floor to living room. The kitchen floor is around 12mm higher than living room flooring. The lounge is floor cypress pine and is essentially the subfloor, the kitchen is some very old linoleum that I've laid vinyl planks over for simplicity since the old floor was glued down solid.
Thank you!
Welcome to the Bunnings Workshop community @chambres. It's great to have you join the community. We trust you'll get plenty of help and inspiration for all your projects around the house and garden from our wonderful members.
Our resident Bunnings D.I.Y. expert @EricL will be happy to recommend a product for you when he is back on the site this afternoon. In the meantime, you might like to upload a photo or two of the transition so members can see what you are working with and be in the best position to share advice.
Please let us know if you need a hand uploading photos.
Many thanks,
Hello @chambres
Thanks for sharing your question about transition strips. Because of the height difference between floors, I suggest using either the Roberts 1.65m Silver Junior Ramp Floating Floor Trim in combination with Roberts Ramp And Cover Trim Plug or the Cap Vinyl Edge Qep Cork 15-7505 in conjunction with the Trim Multi Pin Less Base 1.65m Silver 41-7108-mb. The cap vinyl edge comes in several colours, I suggest having a good look at the store and seeing which one goes well with your flooring.
If you need further assistance, please let us know,
Thanks Eric, will give it a crack!
