Can I lay planks in roof space?
meldarl
Hi Everyone,
I need to run a couple of Ethernet cables, but I'm concerned about walking in the roof space. Can I lay a few timbers down and crawl on them? I weigh 80 kg.
Would something like this work? https://www.bunnings.com.au/specrite-1200-x-600-x-18mm-timber-multi-use-pine-panel_p0419619  Or is there a cheaper alternative I can use?
Thanks,
Re: Can I lay planks in roof space?
Welcome to the Bunnings Workshop community @meldarl. It's brilliant to have you join us, and many thanks for your question about walking in a roof space.
If you are not confident entering the roof space, I recommend you consider employing the services of a professional to do the job. That being said, if you do decide to go ahead, I think you'll find structural flooring to be a cheaper option. It's more than adequate to support your weight, and the team in-store can cut it down into more manageable sizes. It can be laid of several roof timber to provide a surface to traverse on.
Thanks Mitchell!
