Can I buy and install a pre-hung door?
templarkk
I have now built a stud wall first time ever. I have a door openning with dimensions as below.
Can I find suitable standard sized pre-hung door including door jamb available from Bunnings?
There is a 720mm door at Bunnings but if I add 19mm door jamb, that will become 758mm which leaves me pretty much no room to shim.
Thanks.
Re: Buying and installing a pre-hung door
Hello @templarkk
Thanks for sharing your question about purchasing a pre-hung door. Unfortunately, your door opening is non-standard.
The good news is that it is possible to order a custom Hume prehung door at the special orders desk. I suggest double checking your measurements and making sure that the opening is square. If not take measurements both from the top and bottom of the opening before you go to your local store.
Proceed to your local store and speak to a member of the special orders team and ask for a quote for a pre-hung door from the Hume catalogue. Have a look at the brochure and see which door you would like quoted. The team will get a quote for you, and you can then decide if you wish to proceed.
Here is a handy step-by-step guide: How to install Pre-Hung door System
templarkk
https://www.bunnings.com.au/hume-2040-x-720-x-35mm-primed-mdf-accent-hag9-pre-hung-internal-door_p20...
I have a table saw. Will this one do the job instead of going for special order?
I can probably just rip off the hinge side by a little bit?
Does the 720mm mean the whole system width or it's just the width of the door?
Thanks
Hi @templarkk,
That is a door with installed hinges, so the width specified is that of the door. It's not a door that is pre-hun onto an assembled door jamb. If you were going to cut down a door, you'd typically go for one that hasn't had the hinges installed, as you'll be cutting off the rebate for them. However, you could trim a small amount off the non-hinge side.
thx for the advice. will have a 2nd thought and then make a final decision.
Regards
