Best seal to stop rain under front door
jason63
Community Newcomer
Hi all,
We were wondering what the best seal to stop rain water coming through our front door (predominately under the door)?
There's a small gap that's wider towards the hinge.
Thanks!
Re: Best seal to stop rain under front door
Hi @jason63,
Assuming your door is no wider than 920mm, I'd suggest using this Raven RP3 Door Seal, which is designed to seal inward-opening doors.
Check out the video on the product page to see it in action.
Let me know what you think.
jason63
Community Newcomer
Hi Jacob. Thanks for the reply! Is this the door stop that's already currently installed: 
Hi @jason63,
It looks like it is.
Are you missing the small, angled block on the frame that makes it kick downward when the door is closed?
If so, then our Spare Parts team can help you out with ordering a replacement.
jason63
Community Newcomer
Yep, looks like I'm missing the cam that pushes it down. It also does look like it runs a bit short both sides.
I'll get in touch with spare parts, thanks!
