how do I attach the rust look wall panels to a brick wall? do they come with attachments?
Welcome to the Bunnings Workshop community @kestrel1. It's marvellous to have you join us, and many thanks for your question about mounting a screening panel.
Would you be able to provide some details of the panel in question? A link to it on the Bunnings website would be helpful for our members so they know what you're working with.
If it were a panel such as the Tuscan Path 1800 x 900mm Fern Rust Screen Panel, then you can drill holes in the corners and use screws into masonry plugs you've inserted in the wall. These Stahl kits are a convenient option as they include the screws, plugs and drill bit. You will need an additional steel drill bit for the panel. Here's a helpful guide: How to drill into brick.
Thank you. That is the panel I was considering. I think I can do it now.
