Hi I plan on making a kids mud kitchen with this old sink. Are you able to please advise what connections I need to connect the water tap to a garden hose?
Hello @alliras
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your mud kitchen hose connection.
In order to get the plumbing working again, I suggest using a Brasshards 15mm Brass Threaded Cap on the hot side fitting. For the cold side, I recommend using Brasshards 20 x 15mm Brass Threaded Hex Reducing Bush. This will allow you to connect a Pope 12mm Universal Tap Adaptor or similar, which will then allow you to plug in your garden hose.
Just remember to put a catch bucket under the sink so that your kitchen cabinet does not get overly wet.
