Golf course island green construction USGA SPEC need more help with increasing the water pressure
Hi @Mathewb,
Building an island green to USGA specifications requires a reliable irrigation system with adequate water pressure.
Start by checking the pump capacity and pipe sizes to ensure they can handle the demands. Adding a booster pump or using high-pressure nozzles can improve performance without major system changes.
Pressure-compensating valves and dividing the green into smaller irrigation zones can also help maintain consistent pressure.
Regular maintenance, like inspecting for leaks or blockages and using flow meters to monitor delivery, keeps the system running smoothly.
For detailed setup or upgrades, it’s best to consult a professional to ensure everything meets your needs.
