How to replace electrical meter box timber door?
damien-22
Cultivating a Following
Needing to replace door on electrical meter box, what wood panel can be used for this?
something that wont rot and get damaged with water?
Re: electrical box wood
Hello @damien-22
If the former cover was wood, I suggest using Marine plywood for outdoor durability. But if you can find an original metal cover it would be technically safer as it will not catch on fire should an electrical fault happen inside the box. Another type of wood you can use is Merbau, it is often used for decking and is usually pre-oiled.
Please take appropriate care when working near your electrical meter box. Make sure to wear personal protection such as rubber gloves and goggles.
Let me call on our experienced member @CSParnell for their recommendations.
damien-22
Hi Eric. Yes the former is wood.
Is there a metal cover material at Bunnings that could be used to replace the wood cover?
What are the dimensions of the box @damien-22?
damien-22
Hi Jason. 415 x 735mm
Hello @damien-22
I suggest looking at the 1220 x 610mm 12mm Plywood Hardwood Marine AA Grade. I then recommend using Porta 42x18mm 2.7m DAR Rectangle H3 Primed FJ Pine to frame it.
