Hey There ,
I want to building a deck 4m*3m ,it’s very solid and sloping ground ,height100mm- 400mm above the ground. What sort of timber post I should use .
thanks
Hi @ramanpal,
The first thing you should do is confirm whether your local council has any requirements relating to the construction of a deck. If they do, then you will need to confirm the suitability of the design with a draftsperson as plans will need to be submitted to council for approval. It is likely due to the size, you won't need building approval, but it is always worth confirming with a quick phone call.
Typically, you would use a H4-treated post, in either pine or hardwood, that is either 100x100mm or 90x90mm.
You might like to check out the following articles for some further guidance and information.
