concrete H4 post
stu2
concrete H4 post
Hi and thanks
starting retaining walls from 400mm high to 1m high .
using 150 mm rounds at 1.1 spacing ?
how many bags concrete per hole ?
Will be going approximately 50%of lengths in ground
thanks again
Re: concrete H4 post
Hello @stu2
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your retaining wall.
Just a friendly reminder that your retaining wall might need a permit depending on where you are located. For example, in NSW anything over 600mm will need a building approval or permit from your local council.
In regards to the number of bags of concrete, it all depends on the size and depth of the hole you'll be digging, less the diameter of the post you'll be putting in.
My best advice is to use Bondall 1L Monocel In Ground Timber Protector - 1L to add extra protection to your post.
Here is a handy step-by-step guide: How To Build Retaining Wall.
stu2
Great starting point
thanks
