Hey team, can anyone suggest paint for the driveway, porch, roof tiles, and exterior brick?
Hi @Harbajahn,
Thank you for your question about paint recommendations.
For the driveway, you could use a concrete paint system such as the Dulux Concrete and Paving Range. Is the driveway sealed or unsealed? Do you have some photos you could upload? The condition of the driveway would determine which specific products from this range you can use.
You can check out How To Paint a Concrete Driveway for some guidance on this.
Can you advise what specifically you are looking to paint on the porch? Are you looking to paint the ground on the porch? Or wall sheets? or timber?
The specific material would determine what paint should be used. If you could upload some photos this would certainly help.
I am not aware of products that can be used to paint roof tiles. I'd suggest contacting a roof restoration specialist for this part of the painting project. They will be able to select the correct paint and apply it in a safe and warrantable fashion.
To paint exterior brick, I'd suggest using Crommelin Water Based Brick And Render Sealer followed by Dulux Weathershield.
Check out How To Paint Your House’s Exterior for some guidance on a similar project.
Let me know if you need a hand uploading images of your porch and driveway, I'm happy to help if required.
