Materials
Tools
- Paint I used Taubmans Sun Proof (exterior grade - water clean up)
- Paint bucket
- Safety equipment (mask, goggles, gloves)
- Sugar Soap
- Painter's tape and plastic sheeting, cardboard or drop cloths
Other things to consider:
- Paint primer (if needed)
- Sandpaper (if needed)
- Brush or broom
- Paint sprayer (I used Dulux Rapid Finish Wagner)
- Ryobi Drill & Brush
- Paint brush (to tidy any runs etc)
- Funnel with a filter or old stocking (to ensure the paint has no lumps that might clog your sprayer)
- Gurney or high pressure hose
- Sander (if needed)
- Ladder (if needed)
Steps
12345678
Step 1
1/8
The first step of the project involves preparing the surface by cleaning.
I used a brush to remove any cobwebs and dirt.
I then used some sugar soap and my Ryobi drill with a brush attachment to scrub the fence.
And finished off the cleaning process with a gurney/hose.
Note: Some people also recommend sanding the surface before painting. I did not do this, the fence is quite old, warn and has holes I wasn't repairing so didn't feel the need to go too overboard.
Next Step
Step 2
2/8
I let it sit and dry for a couple of days while I monitored the weather for a nice warm, dry and wind free day.
Previous StepNext Step
Step 3
3/8
On the day of painting, I marked off all the areas I didn't want overspray. You can lay down drop cloths or plastic sheeting along the base of the fence to protect the grass or nearby surfaces from overspray. Use painter's tape to cover areas you don’t want painted, such as posts or gates.
Tip: Be very mindful of the overspray, this is also another reason to choose a wind free day.
Step 4
4/8
Thin and mix the paint in an extra paint bucket.
For my spray gun I was recommended 10% water to the mixture. I was also told to strain the paint to insure there were no lumps. I did this with the funnel with a filter, but you could use an old stocking.
Tip: Make sure you mix enough to do the whole project so you don't have to stop halfway through and mix again as this may clog up your spray gun.
Step 5
5/8
Set up your paint sprayer according to the manufacturer's instructions. Make sure it’s clean and ready to go.
Before spraying on the fence, test the sprayer on a piece of scrap wood or cardboard to ensure the spray pattern is even.
Step 6
6/8
Spray the fence.
I started spraying from one end of the fence on one angle in an up and down motion and work my way along, then went back and did the other angle. This helps avoid getting overspray on areas you've already painted and makes sure you get the different angles of the colorbond fence.
Tip 1: Hold the sprayer about 6-12 inches from the fence and move in smooth, consistent strokes. Avoid stopping or starting directly in front of the fence to prevent drips. Slightly overlap each pass of the sprayer to ensure full coverage. You can adjust the sprayer nozzle for a wider or narrower spray pattern depending on the surface area.
Tip 2: Apply thin coats, letting each layer dry before applying the next. (Once I got to one end of the fence I could start again.) This will prevent drips and streaks and ensure an even finish. If you see any drips or runs I fixed this with the paint brush let it dry and then gave it another coat.
Step 7
7/8
Once I finished painting, I thoroughly clean my sprayer, and other items. (clean sprayer according to the manufacturer’s instructions to avoid clogging.)
After the paint is dry to the touch (but not fully cured), carefully remove the painter's tape and plastic sheeting.
Step 8
8/8
Inspect the fence for any missed spots and touch them up with a brush or spray.
Previous Step
Re: Spray Paint Colorbond Fence.
Hi @Herrenovacation,
Well done on completing your fence transformation! It’s great to see you take on such a rewarding project. The effort you put into prepping, painting, and paying attention to the details really paid off. It’s always impressive to see how D.I.Y. projects can make such a big difference in both aesthetics and value.
Many thanks for sharing!
Good Evening @Herrenovacation
That looks brilliant! :smile: I was looking at my tired blue colourbond fence the other day and here is the perfect example of what can be! :laugh: Will be stepping through your instructions a few times i think!
Well done!
Tinker_Bell
Having an Impact
Fantastic job @Herrenovacation
The Colourbond paint has completely transformed your fence from the raw timber. You really nailed it with the spray gun advice you got.
Thanks for sharing how you did it! Your detailed explanation is very informative and I am sure will give others the confidence to give it a go.
Tinker_Bell
Herrenovacation
Making a Splash
Thanks All,
Yes @MitchC I'm actually really surprised how much it transformed this space.
@Dave-1 I look forward to seeing your results, please reach out if you have any questions.
I'm glad you found my explanation detailed and informative @Tinker_Bell
