Outdoor Sauna - Timber use
darcyDIY
Going to be building an outdoor sauna in the backyard (this will be the inspo Family handyman Sauna) with some changes such as a vent, flat roof, tile floor and slightly different size 2.0m L by 1.2m W and 1.8 H approx. Still in the early planning stages but once all sorted and done and dusted will post the journey of what we've done
Biggest question at the moment is figuring out what framing timber is best and safe to use. Seeing as it's a sauna will H2 be okay for the framing? And H3 okay to use for the base of the build? Also wondering if fibre cement sheeting is okay to use for the interior ceiling?
Essentially will H2/H3 be safe to use for a sauna? Or should I go for untreated timber for everything?
Re: Outdoor Sauna - Timber use
Afternoon @darcyDIY
Now that is an exciting project. One that I do admit I havnt tried before :smile:
-I would suggest H3 timber throughout, mainly becuase of the high humidity that will be in and around it.
-Flat ceiling possible a no, A slope ceiling will help condensation roll off.
-Not sure about the fibre ccement sheeting for a suana is about all.
I did notice that the dimensions are all imperial, makes me think that the products that are "off the shelf" overseas may not be so common here, but can probarrly be factored in.
A few of the other members might have some more ideas @Noyade@Jewelleryrescue and @Nailbag
Hi @darcyDIY
I've not built a sauna before only been in a few. One thing that common, is they have all been made of cedar. for a range of properties that suit both the internal and external environments. Anything treated would definitely be out of the question.
Check out this link I found which has some pretty good advice on what to use and planning process from build materials to heating.
