This was one of my more basic projects which got a bit tricky as I wanted to incorporate an old steel shelving which became redundant as I replaced it with a much more heavy duty one. Also I wanted to use tiles both on the top of bench but also for the front sliding doors The size of tiles pretty much determind the layout of the shelving. After a visit to Bunnings Tile section I took some of the dimensions and also sizes of the heavy duty Tubs which I planned to use as Wash tubs. I used Treated pine to frame the tiles and a few coats of Dulux weathershield Gloss Grey. I also spray Painted the tubs to Match also using Dulux plastic coat which adhered perfectly. Considering that not a lot of planning went into this project it transformed a rather dull section into a bit of eye catcher. Also decided to collect all my bonsai and display them together. Needed also to attach a couple of glass shelves above the bench from the bunnings range. An adjustable racking for all the bits and pieces. A properly cut piece of perspex laid across the tub which gave me a bit more working space.
Thanks for your generous comments EricL. You would be surprised how little time you need to maintain once you set up a proper watering system.
The summer heat is obviously the worst as these are shallow rooted but as long as you have adequate shade and a regular watering system and perhaps some uv light for overcast days then all is good. The tubs also work a treat for occasional soaking. The clear containers that I display them in have worked a treat as any runoff is caught and heps raise the humidity in the summer heat. Although its always risky to have a shallow rooted plant outside especially with the unusually high temperatures.
@alicanterenodb love your Camellia in full bud too !! Beautiful ☺️
Hello @alicanterenodb
Thank you very much for posting those extra photos of your plant collection. They look wonderful, it must bring you so much joy just walking into this area and seeing everything blooming. I totally agree that your Azaelias and Camelias really make you forget about winter with their beautiful colours.
Thanks Eric its my pleasure.
