Leaking water at solar hot water system
ppp
Having an Impact
I've got rinnai solar water system. Today I have observed that lot of water leaking from the pipe which is connecting Mains to the system.  Can anyone guide me how to fix this ?  Thanks a lot.
Adam_W
Workshop Legend
Re: Leaking water at solar hot water system
Hi @ppp You can fix it quickly but temporarily with silicone tape but you'll need a plumber to do the proper repair.
If it's only a new(ish) install the installer should be repairing that as an emergency job.
Noyade
Is that a split in the copper pipe below the join?
And on internal side of the bend?
What would cause that?
All looks very new.
As above, plumber.
ppp
Having an Impact
Thanks both of you. I will contact professional for fixing this. Installed more than 3 years ago. Not sure about warranty. Will call them and find out.
Just one questions pls, Do you think I should call installer company only (Rinnai) to fix this ?
OR  can I call any plumber is okay for this job ?
Noyade
Hi ppp
I'm very interested and sympathetic to your plight as I had a gas hot water system (Vulcan) installed this year. In my case - I'd definitely contact the plumber or company who installed it. I'm no plumber - but a weird place for a crack?
And in the meantime use that tape Adam mentioned above.
Sincerely, best of luck.
