I have a concrete Buddha Water feature that had pieces cracking and falling off and generally needs a refresh. I fixed the cracks using Bondcrete sealer, bonding and admix to mortar. Now I want to waterproof the basin again. Some of the concrete in the basin is exposed but some still has paint on it. What can I used to effectively waterproof it? Can Crommelins Waterproofing Membrane Sealer be applied over paint and concrete and then the Crommelins Pond Sealer be put over the top? Is that the best way to do it? Any help would be appreciated as I am a total novice!
Hi @TashB nice project
You already have the solution in you hands, well done using admix bondcrete for the top half
plus mortar.
Bond crete mixed with pure off white cement this time 3 coats will give you a white water proof seal.
If you add some bright yellow sand to make a mortar your familiar with. will give your a more sandstone look and colour,
Cement 1 part , yellow sand 1 part 1/2 part bondcrete add water to make thick syrup as paint.
I have it in big pond now it is solid and non leaking.
https://www.bunnings.com.au/australian-builders-20kg-off-white-cement_p0037905
Boncrete and cement will make a white cement paint that will bond very well and water proof very well. no extra required.
Crommelins Waterproofing Membrane Sealer is not UV stable and I had it fail in my pond cracking up needing redoing which was a lot of hard work.
To assist your use a Mortars brush (But a regular brush will work for small area,)
I/N: 0960322
$28
Hi, thanks for the quick response. The bondcrete says on the packaging that it's not intended to be exposed to water, moisture or dampness or to be used as a surface water protector (unless used as admix). So is what you are suggesting creating an admix mortar paint and that will work?
Yes an admix paint will seal the concrete walls as it combines with cement powder and forms a water proof layer.
Cement on its own is water proof at higher strengths the bond crete binds the cement to the walls better as a paint .
If you want you can add a secondary sealler and color your pond if you wish just make sure it says clearly uv stable if it dont state UV stable then it probably isnt. I learnt that the hard way I used crommelins pond sealer NON UV only indoor.
For my pond I will go Nu tech Nu pool coating great colors and rock solid water performance but only comes in large pails not good for your pond size. sadly and a little too much for mine but enough to repaint in 10 years.
You could get away with acrylic outdoor paint over the bondcrete admix should last for 10 years any color you like?
Hello @TashB
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thanks for sharing your question about waterproofing your old fountain.
When using the Crommelin products it's either one or the other but not both. The Crommelin 1L Clear Pond Sealer is great for waterproofing ponds and water features where no joins or internal corners are evident.
The Crommelin 1L Exterior Grade Brushable Waterproofer is the next step up. It's a synthetic rubber-based membrane, designed to deliver exceptional waterproofing performance in areas subjected to permanent immersion, areas of non-exposed pedestrian traffic or in application under screeds and toppings.
It's permanently flexible to accommodate structural movement and has excellent adhesion to a wide variety of substrates. It has Low VOC and has a fast-drying time. It's suitable for permanent immersion and storage of potable water.
Aside from its difference in features, the Exterior Grade Waterproofer is grey in colour.
Between the two I suggest having a look at the Crommelin 1L Exterior Grade Brushable Waterproofer as it more robust than the clear sealer.
Hi, I did as you said with the sand, cement, bondcrete admix. I put the final coat on 4 days ago. I filled up the basin yesterday and when I was adding the water it frothed up like it did when I washed the bondcrete out of my paint brushes. This morning there is a surface scum on the water of what I assume is the bondcrete. Does that mean it's not sealed properly? I did about 4-5 coats over 2 weeks. Other than that the fountain looks great! I'm just worried the boncrete admix hasn't sealed the basin properly and will continue to leak out.
The surface scum
Hello @TashB
It's possible that the last coat of BondCrete has not fully cured and is mixing with the water. I suggest removing the water and giving the area an extra week to totally dry off before attempting to fill it up with water. Let me call on @Jewelleryrescue to make them aware of your questions.
Hi @TashB
I am 100% aware of what you are seeing boncrete and cement make a chemical reaction and bond well. My pond also at first ozooed excess unconverted bondcrete as far as i can tell but stopped in about a month it also took on a grayish color too, But it is holding water for 5 years now 7000 litres plus on brick works. I would be sad to here if your results differed from long term success, I am sure it will suit your application.
In this pond I used to loose 30mm water a day (Too fast for evaporation) Now every rain I and I am having to pumping water out as it is being re modeled in time.
To fully disclose I also plan on a second cement paint with a more expensive polymere because i am paraniod about leaks. An extra strong physical coating like bond crete. And them over paint that with a blue coloured water pool membraine from Nu tech which is super robust again and pretty.
So I am over leaking ponds lol and i need it 100% uv stable the
Biggest failing point of many water proofs outdoors If it dosnt say UV safe it probably isnt.
Great work doing 4 to 5 coats that 2 coats more than me this fills me with convidence yours is a sucess You and I probable added that extra bit of unneeded bondcrete into the ratio, But no harm done.
So Probalbly keep plant out short term just in case but bondcrete is potable mix so should not harm anything.
