How to restore old concrete pots and statue?
charlottedella
Hello experts
is there any products you can recommend to clean this pot and statue? I would like to remove the yellow staining if that is possible? Thanks in advance
Re: restore old pots and statue
Hi @charlottedella,
The pot appears to be made of concrete, so I would suggest starting by pressure cleaning the pot and then using Chemtech Concrete And Driveway Cleaner alongside a Heavy Duty Scrubbing Brush.
If you can confirm the statue is made of concrete, you can use the same method, but I am not so certain that it is.
If it is made of stone, such as marble, I would suggest using the same method but use Peerless JAL 1L Deep Clean Slate and Hard Stone Cleaner as opposed to concrete cleaner.
Thank you so much for your help @JacobZ
No worries @charlottedella,
Keep us in the loop if you run into any further questions.
Our helpful members, my colleagues and I would surely be happy to assist further if required.
