How to replace my bricked in letter box?
rhys1
Hi, I need to replace my letter box I got home from work today and found the front of my letter box had been ripped off the measurements are roughly W 260mm x H 165mm x  L 355mm just need some advice if there is a product that can fit in the hole.
Regards Rhys
Noyade
Re: How to replace my bricked in letter box?
OK - done deal @rhys1 .
I'll probably get to the Post Office on Tuesday or Wednesday.
I have your address via Jacob.
The opening is 230 mm - which should easily fit within the 260 mm figure you gave me.
You still have some serious drilling and anchoring ahead of you. This thing is solid 5 mm thick steel and weighs 3 kg.
If it doesn't work out - use it as a door stop. 😁
Cheers.
