Hi, I need to replace my letter box I got home from work today and found the front of my letter box had been ripped off the measurements are roughly W 260mm x H 165mm x L 355mm just need some advice if there is a product that can fit in the hole.
Regards Rhys
Not sure how to start a private message still very new here
Hi @rhys1,
Have a look at the Help section of Workshop for some guidance.
Here are the relevant steps.
To send a private message:
Let me know if you run into any issues.
Hi @rhys1 , it’s good to see that @Noyade is helping you.
i found this in the Bunnings website that might also help.
https://www.bunnings.com.au/sandleford-160-x-235mm-aluminium-brick-in-letterbox-set_p2940313
Afternoon @rhys1
@JoeAzza has provided a link to a letterbox front which I did see earlier today whilst googling - it's 235 mm wide. If your 260 mm dimension is accurate - then too small?
Below is the 'solution' I have. Don't be put off by the steel appearance - I can grind and burnish it after welding.
The big question is - how big a letter opening do you want? Below is 30 mm and I'm assuming the letter opening needs to be located high on the plate.
The other question is - do you want to drill the anchor holes? I'm not sure by your photo where the brick 'meat' is and the mortar is.
Let me know what you think.
Cheers.
Ned Kelly would be proud...
I measured 260mm inside the cavity from brick to brick to the other side not sure how thick the bricks are, I will probably have to drill the anchor holes myself and try to work out how much meat is on eather side. 30mm looks good.
Thanks again.
Regards Rhys
ive tried to follow the instructions to send a private message but I don't have the option to click on to private message? As you can see in the picture
Hi @rhys1,
Apologies for that; private messaging is limited for new users to prevent spam.
I had assumed that due to your contributions to the community, it would have been activated on your profile.
I have now added this functionality to your account.
Progress.
I added an inward 'lip' - which now gives your postman around 50 mm thickness in mail that can be inserted.
Pretty much done.
I was just gonna spray paint it white, but you may have other ideas?
Your's if you still want it - just let me know.
Couldn't stop myself - @rhys1 - I went with white...
Wow Looks great 👍 thx again, the wife's likes it.
