How to replace a damaged flyscreen?
I have a damaged flyscreen the requires repair or replacement. Is there anything in the market I can use to make another flyscreen
Re: flyscreen repair/replace
Hi @David12,
Since your flyscreen is heavily damaged and needs replacing, you’ll need to start from scratch. First, you can purchase a new flyscreen frame, which is available in various sizes and materials, such as aluminum. After you have the new frame, you’ll need to cut it to fit your window, ensuring the dimensions match the old frame. Once the frame is ready, you can attach the new flyscreen mesh, which comes in materials like fibreglass, aluminum, or stainless steel. The mesh should be stretched tightly across the frame and secured with a spline (a rubber cord). For a full guide on how to replace both the frame and the mesh, check out this step-by-step guide: How to build a flyscreen frame.
Thanks mate appreciate the feedback I have all the materials to put one together from scratch
