How to prevent sparrows from nesting under roof air conditioner unit?
We found that birds had been nesting both in the unit and in the box underneath the unit which they were accessing under a tin platform which had a small gap in it. Although the A/C technician had sealed the A/C unit,, the birds still access the roof via the corrugated roofing as well. What should I do?
Some people had suggested installing gutter guards to prevent birds from landing on the roof. Please advise, thank you
Re: How to prevent sparrows from nesting under roof air conditioner unit?
Hi Eric,
Thank you very much for your assistance.
House front: 13 metres
Back: 13 metres
Left side: 23 metres
Right side: 23 metres
Do you know roughly how much material I need to buy? Please suggest different types of materials? Thanks
Best Regards
sunny
Best Regards
Sunny
Hello @Sunny18
There are quite a few brands in regards to gutter guard, I suggest visiting your local store and having a look to see which one is suitable for your needs. Some of the mesh types come in 8-meter rolls others come shorter. Just keep in mind that the total length you'll need is 72 meters, you may add an extra meter for overlays and adjustments.
For example, one of the longest packs available is the Jack 180mm x 15m Plastic Super Gutter Guard. It is UV stabilized and can withstand harsh weather.
Thanks Eric, I will keep you updated
Best Regards
Sunny
Hi Team
can you please advise which product is better
Hi Team
I hope you’re well
Tradie told me that Jack 110mm Gutterguard Outdoor Fire Retardant
Bristle Guard would suit the colour bond roof more galvanised wire , Jack 110mm Gutterguard Outdoor Fire Retardant because
Bristle Guard Bristle Guard will fit in snug in between the gutters as colour bond roofs usually fall closer to the gutter than tiled roofs.
This product also makes it easier to clean the gutters as you just pull them out and rinse them and put them back in as you can re use them!
Can you please confirm it is true ? Thank you
Hi Eric
I hope you’re well
Just to let you know that the Tradie told me that Jack 110mm Gutterguard
Bristle Guard
would suit the colour bond roof more than install the galvanised wire , Jack 110mm Gutterguard Outdoor Fire Retardant because Bristle Guard Bristle Guard will fit in snug in between the gutters as colour bond roofs usually fall closer to the gutter than tiled roofs.
I’m not sure which product is better to choose .
Can you please advise? Thank you
Hello @Sunny18
I recommend using the Jack 125mm Outdoor Fire Retardant Gutter Bristles. Not only is it easy to install, but it is also easy to take out and clean, simply use the jet function on your garden hose gun and hose off any mud or debris that might have attached itself to the bristles.
Thank you Eric,
Bristle Guard
How many do you need to put in?
Thank you
Hello @Sunny18
You will need 72 meters; this is in accordance with the measurements you provided. It would be better to get the Jack 125mm Outdoor Fire Retardant Gutter Bristle - 6 Pack as it more economical. It will require eight packs to cover the gutters.
Thanks Eric. I clicked the link. Please find the attached photo. 'Jack 125mm Outdoor FireRetardant Gutter Bristle - 6 Pack'- is no longer available, we can only use the similar product “Jack 110mm Outdoor Fire Retardant Gutter Bristle - 6 Pack” so how many in total I need to buy which including the covers as well.
Please advise , thanks
Subject | Author | Posted | |
August 2023 | |||
July 2021 | |||
February 2024 | |||
August | |||
February 2023 |
