How to paint exterior rendered fence?
jhb
Hi
i would like some advice please to embark on my next project to paint my rendered fence a dark grey colour like Dulux Monument.
Please see picture attached. Can I do this? I note the wall is porous and just a rendered surface finish.
if so what products should I use and can you recommend a link to step by step guide or share brief steps and products here? Can I paint directly on?
I’ve attached the finished look I’m after.
thanks!
Re: How to paint exterior rendered fence?
Hello @jhb
Thanks for sharing your question about how to paint an exterior rendered fence.
To paint a rendered finished fence, I suggest assembling the necessary materials such as exterior paint, brushes, rollers, sandpaper, painter's tape, and safety gear. I recommend using Dulux 10L Exterior Paint Render Refresh Weathershield. It is Ideal for rendered surfaces and masonry. It also helps resist mould, dirt and stains.
The first step is to prepare the fence surface: thoroughly clean it by scrubbing away dirt, debris, and any mildew or mould with soapy water or you can use 30 Seconds 5L Outdoor Cleaner Concentrate. Simply spray it on the surface, scrub it with your scrubbing brush and rinse it off. Make sure to let it dry completely. If the existing surface has any damage, I suggest using Earl's 1kg Concremate Expanding Cement to patch any holes or cracks in the surface.
To protect the surrounding areas, cover the ground and adjacent surfaces with drop cloths or plastic sheets to prevent paint splatter. Once ready, stir the paint and begin by cutting in around edges and corners with a brush, then use a roller or brush to apply paint evenly to larger, flat sections. Work in manageable sections, ensuring an overlap of strokes for consistent coverage.
A second and third coat may be needed, depending on the paint's instructions, to achieve a more durable and vibrant finish. Allow each coat to dry completely. Once you've finished painting, remove the protective coverings and clean your tools according to the manufacturer's recommendations. Regularly inspect the fence for wear or damage, addressing any chipped or faded areas to maintain its appearance and protection.
Here are some handy step-by step guides:
How To Paint An Exterior Wall (the techniques used are applicable to your rendered wall)
How to paint your house’s exterior with a spray gun
jhb
Thanks Eric I’ll follow that
Keep us updated on your project @jhb, and please reach out again if you need further assistance.
We can't wait to see your results!
jhb
 hi Mitchell and Eric - here’s the finished result. We went with Dulux  ‘Domino’ colour opposed to Monument. Did three coats as the cream render underneath came through on some rough patches.
thanks for the help!
Hi @jhb
Thank you so much for posting that update. That paint revamp of your fence looks awesome! Have you thought about putting in some fence lights or perhaps some festoon lights to give your fence ambiance at night?
