Garden_Rookie
How to fix damaged Teak chair?
Hi Community!
Hope all is well.
This may be a simple question but I am new to fixing things myself (learning alot here).
I have a damaged wooden chair (teak wood) due to my dog biting it (picture attached)
Can I please ask what the best way to fix this is? Should I sand it down?
What tools would you recommend for this?
Thank you!
Rookie
Re: How to fix damaged Teak chair?
Hello @Garden_Rookie
This should be a relatively easy D.I.Y. fix for you. I propose using Flexovit 115mm x 1m 240 Grit Painted Surface Sandpaper Roll in combination with Paint Partner Cork Sanding Block. The purpose of the sanding block is to prevent creating waves or uneven depressions on the timber surface.
The sanding block will leave a nice even surface to fill. Once the surface is nice and flat again. I recommend using Timbermate Wood Filler. It comes in various colour so please look carefully when matching your timber finish. Fill the damage with filler and wait for it to cure.
Once the filler has cured, you can then sand it down until it is nice and flat once again. Wipe the legs free of sanding dust and debris. You can then spray the leg with a clear sealer such as Dulux 325g Duramax Matt Clear Coat Spray Paint
Please remember to wear personal protection such as gloves, goggles and a mask when working on your project.
Thank you for the comprehensive response.  I will give this a go.
Keep us updated @Garden_Rookie and please reach out if you have further questions.
