Hi, I have a small section outside a garage door which is under-cover of a patio, along the door on the left side is a small section about 12mm wide and 12mm deep running the full width of the door and on the right and front sides of the old pebblecrete is a rough section of concrete which is very even. I would just like to smooth it out level so I could possibly paint it or do something else you might suggest to blend it into the old black and white tiles. I am not in a position to get someone in to dig it out and re-concrete so would appreciate any ideas for a relatively easy fix for an old fella to do. Thank You
Hi @BrianC
Tearing up perfectly usable concrete is hard work so please avoid this us old buggers dont need that exercise.
There is products 20kg floor leveller you can use basically mix it up and pour it on and all the holes smoothing with a Using a metal trowel. will be filled and form a flat concrete surface and you can paint it or tile it, Follow bag instruction.
Mix it in a bucket and pour it on the concrete use the trowel to push honey like liquid into the low spots and fill them a fairly painless task. You will end up with a smooth flat slab.
Maybe a bit slippery in the wet so if you paint it sprinkle some sand on it immediatly after you paint then do second coat when dry.
I am thinking that maybe you might find some out door tiles and glue them over the concrete as a choice. and skip the self leveling bit.
On special at bunnings now is some charcoal matt ceramic-floor-tile-carton-of-9_ $19 and will fill you space.
Just need some tile glue and a tile cutter maybe or angle grinder.
Another option is a rubber mat or your standard door mat. No work required
Thank you, I was thinking Leveller but wasn't sure if suitable for that but after reading comments and reviews I think it would do the trick. I had initially thought about tiles but it is a very even surface so some tile cement would have to be very thick in places and it would also create a ridge where it meets the current patio tiles. So I think the leveller is the way to go. Thank you for your reply.
Hello @BrianC
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about patching an uneven section of your concrete floor.
It's great that you've received excellent advice from @Jewelleryrescue. Just to add to the suggestions made, I also recommend looking at the Lanko 20kg 173 Floor Leveller, Dingo 20kg Floor Leveller and Dunlop 20kg Ardit Floor Leveller. These floor levellers are all rated for outdoor use and among the three the Dingo floor leveller is suitable for use in wet areas. Looking closely at the photo you posted does water gather on the low section of the floor when it rains? Does it drain away or does the water simply evaporate during the day?
The reason I ask is because if you level off that section will the water still drain properly, or will it flow towards your garage? It's just one of those things you need to take into consideration when you relevel your concrete floor. Should you decide to use the floor leveller, I also recommend using the Dunlop 4L Multipurpose Primer in order to enhance the bond between the two materials.
Hi @BrianC
again agreeing with both @EricL and @Jewelleryrescue on using the floor levelling product. I have attached a few before and after photos of a couple of floors I needed to level prior to tiling. I use the Davco product which I have found excellent.
A couple of very import tips:
Use a level to check and mark with chalk the low points to where it meets the level you need to acheive.
If there is any outer areas the leveller can seep out to, dam is or it will find its way out.
