How to fill gap between pavers and retaining wall?
Scootergirl
I have a small gap between a strip of pavers and a garden bed retaining wall. I recently pressure cleaned everything - but with all the rain we’ve had, I think that earth is splashing up from the pavers onto the retaining wall. I’m hoping that by filling in the gap, it will stop this happening.
what would I use to fill this gap?
Scootergirl
Another paving question
I have a strip of pavers, and there is a concrete (I think) edge - but some of it has broken away & there is now a gap between it & the pavers.
Next to that there is a strip of earth, & a strip drain. This is where the gutters overflow in the torrential QLD rain, & the earth has washed away a bit; and moss grows on it.
How can I fix these 2 issues?
Jewelleryrescue
Re: How to fill paving gap
Hi  @Scootergirl
I would highly  recommend a polymer  sand that brushes in between the paver cracks and sets to form a  bond between  pavers.
Just  follow there instructions.
This will lock the dirt  from washing out done right.
Dingo 20kg Powerloc Polymer Paving Sand
I/N: 0760478
Re: Another paving question
Hi @Scootergirl
I would  dig /scrape out the  cement  crack and dig out the dirt besides the drain.
I would use  pre mixed sand and cement and fill both the crack and where the dirt is making that a solid cement strip between the  drain and  pavers.
This process can  be done gradually a bag of sand and cement at a time no rush.
Buy a  cement trowel to help you,
Australian Builders
Australian Builders 20kg Sand And Cement Mix Bag I/N: 0760612  $10.07
Craftright 175mm Gauging Trowel I/N: 5960143  $6.98
https://www.bunnings.com.au/craftright-175mm-gauging-trowel_p5960143
hope this helps.
Hi @Scootergirl,
We've combined your posts as they provide context to each other.
The dirt building up on your walls is because water has collected sediment and then sat against the wall and deposited that sediment. Fixing this is all about fixing the drainage.
The first thing I'm noticing is that your drainage channel looks like it is sitting higher than the level of the pavers. This is likely the major contributing factor to the water pooling in this area.
I'd suggest lifting the drainage channel out, digging out the dirt around it and setting it back in place. You can use the EasyDRAIN Standard Installation Instructions as a guide for reinstalling it.
By reinstalling the drainage channel to a level below that of the pavers, the water will drain far better.
Once the drainage channel has been installed at a lower level, you can sweep polymeric sand such as this Dingo Powerloc Polymer Paving Sand between the pavers and up against the wall. You should then wet the sand down to activate the polymer which will lock the sand in place.
This will allow water to drain through the pavers but won't let it pick up the sediment from beneath and deposit it against the wall.
Scootergirl
It’s actually 2 different areas in the garden with different issues which is why I posted it as 2 seperate posts. The drainage channel isn’t near the retaining wall - & it sits below the level of the pavers it is adjacent to. Here is a photo showing the different areas of the backyard.  
Thankyou! I will do this
Hi @Scootergirl
It's great that you've received excellent advice from @Jewelleryrescue. Just to add to the suggestions made, please make sure that you clean the gaps thoroughly before you put sand into the gaps.
