How to build outdoor wood feature wall?
allred1477
Hello,
We are looking at building an outdoor feature wall made from wood slats. It will be exposed to the elements mostly morning sun and will get rain. We will also paint it white.
What would be the best type of wood to use for the slats as well as the frame to attach the slats to? We want to keep the profile as thin as possible.
We are attaching the frame to brick so what would be some options for hardware for this?
Thank you!
Re: How to build outdoor wood feature wall?
Welcome to the Bunnings Workshop community @allred1477. It's tremendous to have you join us, and many thanks for your question about wooden screening.
I'm so sorry for the delay in my reply. You might like to consider using some of our prefabricated timber screening panels for your project. They are suitable for external use and would be easy to fix on your bricks with masonry fixings. Due to them being panels, they would be far easier to fix in place than individual slats. If you were to use slats, I'd recommend fixing a few horizontal battens to the wall first, which will then allow you to screw the slats to the battens with external timber screws.
Slat selection-wise, you could consider 69 x 15mm 2.7m FJ Pre Oiled Merbau Screenin or 42 x 28mm 2.7m FJ Pre Oiled Merbau Screening - 28mm. If you were to go for Tasmanian Oak, you could reduce the profile thickness down to 12mm.
