Hi All,
Newbie here and started doing small DIY stuff like making merbau planter boxes :). Now I am planning to start my decking and found this forum extremely helpful gaining the basic knowledge about decking, especially guidance from @MitchellMc in similarly low level decking threads. Here is my project details (please refer the photo attached -
Questions:
1. Ground clearance in A is 31mm (140 - 109), B is 41mm (150-109) and C is 81mm (190-109). Based on this, is L-bracket a good option? If yes which L-bracket should I choose?
2. With L-backets, I probably have to use shims underneath the joists, isn't 81mm too high for using shims? what are the other options I got? Looking for options other than EcoDek foot (planning only to use it in the pebbles area D).
3. Need help with detail specs of dynabolts, L-brackets etc. suitable for the above project.
Many thanks :).
Morning @Sujoy
Those concrete anchors are a little long The deck is only low and wont have a lot of movement so id go with something shorter. either a 50mm or a 60mm anchor Ramset 8 x 60mm Galvanised AnkaScrew Masonry Anchor (box 10) Id be wanting 50mm into the concrete type deal.
With your bearer turned sideways I am not so keen. I know the span is short but my head baulks at the flex. How about taller styled right angled brackets and do away with the bearer entirely? Dunnings 60 x 100 x 35mm M10 Galvanised Angle Bracket
You can still attach the skirt to the ends of the joists. In reality you could use the bearer or the right angle. Im trying to think of a reason other then personal preference
What you're doing looks fine @Sujoy. As @Dave-1 mentioned, it is best to have the bearer in the upright configuration, though as long as you support it readily, there shouldn't be too much flex.
There's no particular need to coat the underside of the bearer with bitumen, as they are treated for above-ground use. However, if it comes in contact with the ground or is very close to it, you might like to.
Those screws look fine. I suspect you need the length to go through the bearer, the air gap and then into the concrete. Just ensure at least 30/40mm is screwed into the concrete.
@MitchellMc @Dave-1 Thanks, I had no option but to turn the bearer sideways as total clearance was only 80mm. I first fixed the packers under the bearer and drilled 8mm hole through the gap between the packers and then screwed using the 8mm galavanised Masonry Ankascrew into the concrete. The screws are every 450mm, and has gone 45mm into the concrete making it very sturdy. Also added joist tape to avoid moisture accumulation on the top. Attached photo for reference, hope this is fine? The overall levelling seems to be alright, progressing well 😊.
Another question re the screw for attaching angle brackets to joists, is the screw shown in the 3rd photo ok to proceed with?
