I want to make a boxing for a relatives grave.
I have 2 x 200 x 95mm x 1.8mm redwood sleepers
I need 2 x 200 x 95mm x 900mm redwood sleepers
If a buy another 1 x 200 x 95mm x 1.8,
1. Will Bunnings cut this in half for me?
2. Drill the holes needed to screw / bolt together?
3. Advise on the screws, nails or bolts needed for my project?
Or let me know where I could have these things done for next to nothing.
I'm on the North Shore
Thanks in advance
Welcome to the Bunnings Workshop community @arts64. It's terrific to have you join us, and many thanks for your question about creating a boxing.
For sleepers that are purchased at Bunnings, we have a timber-cutting service. Unfortunately, the team at the store won't be able to drill the holes you need or bolt your project together. They can certainly assist with the fixings section, but it sounds like you need something along the lines of Buildex 18 - 7 x 200mm Landscaping Construction Screws.
It would be a relatively simple project for you to complete yourself if you have a basic drill driver, and our helpful community members would be more than willing to provide advice and guidance. If you cannot complete this project yourself, you might like to reach out to your local Men's Shed to see if someone there could assist at a minimal cost or hopefully for free out of the goodness of their heart.
Yes , I got my sleepers from bunnings. I have the tools to put it together but not the cutting tool or drill, will sort that one out.
I will grab screw bits today. I guess I just needed to know the size screws in the end. hehehe
Thanks again
Hi there I am doing a grave yard boxing tidy up , I am wondering what is the best wood and screws I would need to use.
Welcome to the Bunnings Workshop community @kct2796. It's terrific to have you join us, and many thanks for your question about concrete formwork.
For graveyard boxing that will stay in the ground, you’ll want to use timber that can handle constant soil contact. H4-treated pine is the standard choice as it’s designed for in-ground use and will resist rot and decay. You could use sleepers or even H4-treated plinths if they are available in your area. For fixings, use galvanised or stainless-steel screws to prevent rusting over time. This combination will give you a durable and long-lasting setup.
