Hi all,
I am trying to find a cheap way to secure a section of courtyard to allow my cat to the safety and freedom to go outside when she wants too.
My issues are:
I live in a rental with brick walls that cannot be drilled in to.
There's no grass, just concrete and a garden bed.
The neighbouring fence is unstable so cannot use it to secure or anchor
There is another cat that likes to visit & isn't friendly and want him to be able to get out of his own.
I am thinking of setting wooden posts around 2m tall in buckets of cement to which I can then attach netting/mesh for the walls and add angled fence brackets at the top
My questions are:
Would this work the way I imagine?
Would it be stable and not topple over in the wind?
What size buckets would be needed to keep it stable?
Thank you in advance
Edited -
added pics.
Area is aprox 4m long & 3m wide.
Sliding pet door insert for anytime access.
Welcome to the Bunnings Workshop community @Mel_K. It's amazing to have you join us, and many thanks for your question about building a catio.
You're idea could certainly work, but I'd encourage you to use 20L+ sized buckets. Something like this 20L handy pail would work. A concern I have is how you'd get the netting to wrap around the lower bucket section. As an inside cat owner I would be paranoid about my cat getting under the netting.
I recently wrote an article on building a catio (cat-patio), and here are my thoughts:
I'd encourage you to think carefully about how you could use these Tumbleweed Garden Waste Storage Cages. The enclosure could be made entirely from these and joined together with cable ties. Depending on how you design it, it could be self-supporting and need no connections to the house or ground.
The other option is to use bird netting, though you'll need to find locations where you can fix it. If you'd like to post a few pictures of the area, then I'm sure our members could come up with some mounting solutions. Please let me know if you need assistance uploading images.
Welcome to the Bunnings Workshop community @Mel_K. We are looking forward to seeing how you can build a catio for your furry friends.
Just thought I'd add that these are our two most popular cat projects on Workshop:
Thanks,
Hi Mitchell,
Thank you for your response, very helpful and lots to think about. I have put up some photos. I know there's a solution out there, just got to find it
Hello @Mel_K
Have you considered building a temporary frame to hold the net? You can use 70x35 framing timber to build a large area for the catio. Plus if you ever decide to move, the timber can be disassembled and taken with you. It will be heavy enough that the cat won't be able to move the frame. Please have a look at the sketch below and tell me what you think.
Hi Eric
This is quite a late reply, but I just wanted to thank you for the technical drawing of the catio. I'm attaching one into a recessed L of my weatherboard house (where there's a patio) and this is perfect. Thank you!
If I could ask a question, I know you've said "It'll be heavy enough that the cat wont be able to move it" but I've got two pretty excitable Burmese that are heavy (6kg each) - would you recommend bolting it (attaching with brackets) to the patio, and what could I use if I did want to? Also, should I attach it with brackets to the weatherboard exterior?
Hi @RenoLiz
If you decide to anchor the frame to the patio or weatherboard, I suggest using Zenith 38mm Zinc Plated Angle Bracket - 16 Pack in combination with Ramset 8 x 50mm Universal Anchor - 20 Pack. The screw set will work on both timber and masonry, but you will need to pre-drill holes if your patio is made of concrete.
