How to attach Christmas lights to the roof?
AHoy
Having an Impact
I'm getting a bit of pressure from the kids to put up some Christmas lights this year. It's becoming a bigger thing in the neighbourhood. We have a terracotta tiled roof though so I'm not that keen to be up there for too long - I want something quick and easy. Keen to hear from those with experience about how best to attach some lights. Am also thinking a projector is a safe an easy addition.
Dave-1
Community Megastar
Re: How to attach Christmas lights to the roof
Afternoon @Richiet
I dont like mounting things on the roof, I know I am lazy and recovering them after Christmas will always lag so they will end up looking ratty..... :smile:
However Some ideas you could use.
Craftright 300mm 2 Piece Quick Action Clamp You need to be able to go over the ridge of the roof and clamp either side. And not clamp to tight as you wouldnt want to crack the tiles. There are other clamps that you will be able to match to your roof tho. You could then string your lights through the clamps or use them as fastening points.
I agree with @Noyade about not wanting to get on the roof tho. So how about something along these lines.
Construct a large T shapped piece of timber. The long piece is flat, the shortT arm is on its edge. You screw the edge piece to the long piece on the ground so you have a smooth surface and the other surface has a"step" in it.
This is placed flat side up on the roof, the short piece sits in the gutter to stop it wanting to tilt or slip out. I would recomend some small clamps to help it stay in place on the gutter in case of wind.
With this sorted, you could put some screws/hooks, into the top side of the long piece and then hook your light string through it as you push it up on the roof proper. Never having to step on the roof :smile: You get your lights plus you dont chance falling off the roof!
Notes -
Make sure you have rubber feet for clamps on the gutter
May be an idea to have a pice of rubber underneath the long piece tip so it wont scratch or bang so much.
Have a way to get them down if something gets caught.
Nailbag
Kind of a Big Deal
Hi @Richiet
I think the main issue is getting anything to stick securely to the tiles and stay there. I've used that Extreme velcro that @JacobZ has suggested and have been very impressed, though not in your application. If you were to use it, I would consider the roll being the more economical way. The adhesive on those Permastik in my experience is less than great. I've used them to hold cables on office desks and they just pop off. But the clips are great.
I'm a huge fan of suitable silicone style products to fasten objects as they can be very strong in harsh conditions and I can also remove them when needed. So what about removing the adhesive backing on the clips with a sharp blade and then scratch the surface up on some sandpaper and wipe clean. Then clean each spot the tiles with say Isopropyl Alcohol and then fix each clip using roof and gutter sealant. Give them a day to cure and then you should be right to go.
Regards, Nailbag
