How to add pool pump sound proofing?
cade
There is a low machine noise hum from my neighbours pool pumps close to our bedroom windows that operate at night though to the early hours in the morning
A thin rubber mating has been placed under the pumps with out any other enclosure around the pumps
loads of area around the pumps available  for placing acoustic panels and a house Looking down on pumps Looking down on pumpsHouse wall with switch boxes House wall with switch boxeswall to support any acoustic panels
pumps are mounted on a concrete slab
Any advise or experience anyone has on setting up sound proofing around the pumps would be a big help before I head off on a trial be error effort
Re: How to add pool pump sound proofing?
Hello @cade
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about sound proofing a pool pump.
I suggest having a look at this guide - How to build a pool pump cover. The housing will of course need to be modified so that it can cover the entire pump assembly. The inside of the pump cover can then be lined with Bastion 1200 x 600 x 50mm XPS Multi Use Foam Board. This should greatly reduce the machine hum noise, aside from this I also suggest changing the rubber matt of the pumps to something a lot thicker such as the Ideal 1m Black Fine Rib Rubber Matting Sheet.
From your side of the fence, I suggest building a fence like wall near your fence that is in front of your window. You then fill that wall with insulation which should lessen the humming noise even further. The humming noise should now be greatly reduced when inside your room.
cade
Many thanks Eric , excellent information and directions to go about putting it together, it’s most appreciated .
The idea to build a sound barrier wall on my side of the fence is easy to do as there is only pathway with plenty of clearance.
I’ll measure up the area around the pumps for a prebuilt pump cover to drop over the pumps
thank you for the help
cheers
Cade
Bunnings workshop group/ projects is a first class idea 👍
Most helpful
Good Evening @cade
I feel your pain. My pool pump does not have a cover and I know of your hum issue. Yeah I know I should kick my own butt.
However there are a couple of ideas. Someone recently had the same questions as yourself.
Pool pumps cannot run all night, there is a certain time period set by the council. I would check out your local councils website and see.
A cover designed to sit like a box just over the pump and the pre-filter basket should go a long way to deadening the sound.
Ive been thinking of what I could build to go over mine and pretty much it will come down to an exterior ply with a sloped roof lines with foilboard on the inside.
It will look like an old school train set tunnel that drops over the pump and pre-filter. For servicing just lift and then replace.
If you neighbours arnt keen I would suggest as an easiest option for your peace of mind to offer to make the box. I know its a stretch but the neighbour may not be handy, may not have money, may not have time, may not really care but figure nothen ventured means noisy sleep.
cade
Excellent info Dave
thank you
good point to check out the council regs on night time running
good design to put the neighbour
cheers Cade
