How much concrete mix is required?
PeteB8
How much concrete mix or number of 20kg bags is required to cover an area of  2m long x 150mm deep x 400mm wide.
J-TAC
Re: how much concrete mix is required
Here is a link for a concrete calculator that will do that for you, hope it helps
https://www.calculator.net/concrete-calculator.html
Welcome to the Bunnings Workshop community @PeteB8. It's sensational that you've joined us, and many thanks for your question about the number of concrete mix bags you'll need for your slab.
I apologise as I read your measurements incorrectly. I've now edited my response below to reflect the correct amount.
It's fantastic to see you've already received a helpful reply from @J-TAC. Here's another calculator from one of our suppliers using purely metric units. You'll require 14 x 20kg bags of concrete.
We look forward to hearing more about your concrete slab project. Please let us know if you have further questions or need assistance.
how many bags of cement , sand and stones if mixing from scratch
Welcome to the Bunnings Workshop community @mike57. It's great to have you join us and many thanks for your question about mixing concrete.
The normal ratio for concrete is 1 part cement, 2 parts sand, and 3 parts gravel. So, for every bag of cement you'd need, you'll use two bags of sand and three bags of gravel.
What sort of project are you working on?
Please let us know if you need further assistance or have questions.
