Hello and thank you for the help. I’d like to put up some sort of shade joined to the verandah. So our cars can be covered. Can anyone recommend what to do.
Hi @newbuilder,
Thank you for your question about adding a shade structure to your property.
My suggestion is to add a shade sail over the driveway. This would require you to concrete in two posts along the grassed fence line and then find a method of attachment on the house side of the driveway.
If you'd like to attach it to your verandah's roof structure, or to your home, you will need to confirm compatibility with an engineer.
There is also a variety of options for carports that you might like to consider.
Allow me to tag some of our helpful members to see if they have any ideas @Dave-1, @Nailbag, @Jewelleryrescue.
Morning @newbuilder
I like the idea of @JacobZ 's but also like the solidness of a metal carport.
I would go down the track of a new metal carport next to your exitsing verandah, legs and all. Mainly if either carport fails in high winds then there is a chance it wont take out the other half
Something to factor in wether you go shade sal or fixed roof would be to make it higher then usual, mainly because its down the side of the house and you may want/need highish access for a ute or trailer with stuf fon it. Not heaps higher, maybe 500mm above your existing one. It wont look as seemless is all.
