Durring Covid times it was 3months before the fencer would come and quote. With a bricklayer friend we installed some brick pillars and filled in between with Bunnings pool fencing panels, giving the front yard an open yet secure feel.
Pool fencing:https://www.bunnings.com.au/rapidfence-2200-x-1200mm-dark-grey-square-tube-pool-fence-panel_p0261643
Cement: https://www.bunnings.com.au/bastion-20kg-concrete-mix_p0038287
Post hole digger
Angle grinder
Screw gun
Concrete pad footings with brick pillars erected and painted white
Bunnings pool fencing panels cut to size to fit between pillars. Panels fixed into brick pillars and in between steel posts
That looks sensational @EdithHobbs! I bet you are pleased with those results.
You've done an amazing job; well done.
Many thanks for sharing.
Thanks ! We think it turned out well
