Hi Guys
Do you have any recommendation for buying electric / rechargeable pool vacuum for large in ground pool? Need vacuum without the need of existing pump or filtration system
Hi @kalradeepak,
We have a range of electric pool cleaners, including the Baracuda Captura Plus Robotic Pool Cleaner, Baracuda Rova Robotic Pool Cleaner - Floor Only and Baracuda Gotcha Robotic Floor & Wall Pool Cleaner. I haven't personally used these units, but there are some reviews from our customers on the product pages. However, I have used another unit from Hy-Clor, which I found quite effective. My pool hose previously would get consistently clogged with copious amounts of Blue Gum leaves, which would fall into the pool every day. The robot unit had no issue picking up even the largest of leaves. Unfortunately, I've had a look, and this unit is no longer available, though I thought I'd share my experience not using the pump or filtration system. I still used the filtration system to remove particulates from the water that the plugin unit obviously couldn't remove.
I look forward to hearing what our other members' feedback is on this type of cleaner.
